1994 Buick Century
ANNA137
  • 1994 BUICK CENTURY
Engine Mechanical problem
1994 Buick Century 6 cyl Front Wheel Drive Automatic
I have a 94 Buick Century that is having troubles starting when it's warm or been driven for a while and I park go into a store or something and come back to start it again. It turns over. So I know the starter is fine I just have no idea why it acts up when it's warm. Any ideas would help.
Saturday, January 30th, 2010 AT 7:40 PM
JDL
  • 16,098 POSTS
Welcome to the forum. How long since a tune-up? With an extended crank, can you check for spark at the plugs? With a hot engine, you may want to use a plug wire puller, then use known good plug or tester in the boot. Are there any applicable trouble codes? Your obd1, you should be able to get some mil codes.
Sunday, January 31st, 2010 AT 9:19 AM
