Hello sorry so long I have codes now thee codes are listed as follows b1216, b1221, b1225, b1232, b1236, b1295 I look up some of them some didnt pop up so can u help me with these.
Friday, February 15th, 2019 AT 7:07 PM
(Merged)
THOMAS32
MEMBER
Thanka alot but may I ask where is the cran sensor located at and is the module the brain to the car called the ecm and is the pressure suppose to be at 40 psi
SPONSORED LINKS
(Merged)
SATURNTECH9
MECHANIC
Before we explore these codes iam more intrested in why the battery goes dead or the engine wont turn over?That problem can set any number of codes and make us chase are tails. So has the battery and alternator been tested?Also have you made sure the battery cables are clean and tight?
(Merged)
MECHANIC
Pressure 40 lbs, good.
Crank senswor is behind the harmonic balancer and the module is under the coil. The pcm is inside the car.
I would not throw expensive parts at the car without someone identifying the failure. You could spend 1000 in guesses that may not work.
(Merged)
THOMAS32
MEMBER
Ok the psi is not going past 9 with the fuel pressure check what does that sound like
SPONSORED LINKS
(Merged)
MECHANIC
Either a bad connection, bad ground or bad pump. What kind of pump did you use?
(Merged)
TAT24U
MEMBER
1992 BUICK CENTURY
3.3L
V6
FWD
AUTOMATIC
177,000 MILES
The car starts and runs fine for like 10-15 minutes then dies it will start one more time with a little miss then wont start at all unless I floor it to keep it going then stron smell of gas. I changet coil pack fuel pump fuel filter fuel injection regulator and O2 sensor no service engine soon light is on but I manually checked for a possible code and it doesnt show one. I'm lost now and just cant figure it out
(Merged)
THOMAS32
MEMBER
The upgraded version that buick got, got it from auto advantage it is the wide four pronge now, buick no longer have a three prong
its cranking but will not turn over and stay started
(Merged)
MECHANIC
Check the fuel pressure if its within specs then get back with me-we start here
(Merged)
MECHANIC
Did you check the other things I asked?
(Merged)
TAT24U
MEMBER
Im not surehow to respond to you razmataz but yesthe fuel pressure was at specs
(Merged)
THOMAS32
MEMBER
No not yet its raining hard out side but I will check in the morning, where might the bad connection be meaning area and I will also check the ground if thats not it what else might I check also thanks alot for the response I will start workin on it at 9:00 am I will post a message back soon as iam done to give results
SPONSORED LINKS
(Merged)
TAT24U
MEMBER
Sorry I just saw this yes I rented the tester and the pressure was within specs and even though it was I figured since it was a 1992 and most everything was original things were getting tired so to speak thats why I really had no problem changing the fuel pump, strainer, filter, and fuel injection pressure regulator
(Merged)
MECHANIC
Lets confirm this basic stuff first.
(Merged)
MECHANIC
Check the idle air control valve, TPS and MAP sensors and clean out the throttle body-let me know what you find
(Merged)
THOMAS32
MEMBER
Thank you will do
(Merged)
TAT24U
MEMBER
Ok I checked all the components mentioned the idle air control valve had a lot of soot on it it had movement but im not sure how much movement it is supposed to have though and with all the sensors I dont know how to check them with a multimeter so all I can tell you or give you is visual information the map sensor had some soot on it but the platinum wires were in tact and the TPS moved freely
(Merged)
THOMAS32
MEMBER
Olk did everthing took o2sensor off car starts up but when pushing throttle body car sounds to be wanting to die or cut off
(Merged)
MECHANIC
Clean out the PCV and EGR valves-The IACV you probably have to change it-
(Merged)
MECHANIC
Why did you take off the o2 sensor?
You may have a bad cat converter if it runs because you just gave the exhaust somewhere to go.
