1989 Buick Century dash light
JULA
  • 1989 BUICK CENTURY
  • 6 CYL
  • FWD
  • 118,000 MILES
The light for the spedometer does not work as well as the chime to indicate that my lights are on. The light to show that the brights are on works. Is it just a bulb? If so how do I get to it, and where can I find a bulb to replace it?
Sunday, October 26th, 2008 AT 4:38 PM
DLOBI
  • 125 POSTS
If all the dash lights (back lighting to read gauges) are out then it is more likely the switch where you turn your lights on and the dimmer controll to dim down the dash lights.
Silly question, maybe, but is the dash light dimmer simply turned down too low?
If only one bulb is burned out by your speedometer and other backlighting dash lights work it would be a pretty big job to replace one small bulb. You have to take the dash apart including removing the instrument panel. Lights like brights, turn indicators, etc are seperate from the rest of the dash lights.
Monday, October 27th, 2008 AT 7:54 PM
