After shutting the engine off there is a bubbly noise and coolant pours out
2003 CHRYSLER PT CRUISER
84,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DINA SOLMON
A few months ago I had my radiator replaced because it had a crack. Now when I drive it for about thirty minutes or more and I shut it off I hear a bubbling sound. Then a ton of coolant pours onto the ground. My temperature is okay and does not leak other than that.
Apr 1, 2018 at 6:59 PM
HARRY P
  • 2,292 POSTS
You probably just need a new radiator cap. It cannot handle the pressure any more, and is allowing coolant to go by.
Apr 1, 2018 at 8:44 PM
DINA SOLMON
A few weeks before I replaced the radiator I bought a new one. Could it be bad already?
Apr 1, 2018 at 8:55 PM
HARRY P
  • 2,292 POSTS
Possible. It is either going to be that, the thermostat, or the cylinder head/head gasket. We will hope for the cheap and easy fix. If that does not do it, then we will guide you through some basic diagnostics to try and pinpoint the problem.
Apr 1, 2018 at 9:14 PM
