hit the brakes hard. When I got ready to drive, the car would not go
165,000 MILES • 4.0L • V6 • AUTOMATIC
WENHAD
I had to stop quickly and hit the brakes hard. When I got ready to drive, the car would not go. I put it in park and then back into drive, it still would not go. I put the car back into park and turned off the engine. A few seconds later I cranked the car, put it in drive and everything seems to be okay now. Any ideas? Thank you.
Jul 20, 2019 at 8:42 AM
  • 55,676 POSTS
Hmm, sounds like the brake booster or brake pads may have jammed, are the brake pads in good shape? Does your car have ABS? if so we can scan the unit here is how
https://youtu.be/rTtAnsOlZU4
we should run the transmission codes as well
Mar 11, 2021 at 6:26 AM
