Was the ABS module tested bad? I ask because often times a faulty wheel speed sensor can cause the lights to come on. I've even seen low brake fluid cause it.
What I suggest is to have the can bus scanned. CAN stands for controller area network. Basically, all the modules/computers are tied together via a few wires. If there is a code identifying a problem within the ABS module, it will show.
Here is a video that shows how it's done:
https://youtu.be/InIlnsjOVFA
If you already have done that, let me know what codes were found. If there are no codes, check the wheel speed sensors. Here is a link showing how that done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know if there are codes or anything other you can think of that will help me diagnose the issue.
Jun 25, 2021 at 2:38 PM
