1994 Jeep Cherokee want crank
RODWIGGINS
  • 10 POSTS
1994 Jeep Cherokee V8 Four Wheel Drive 120 miles
turning iginiton an aint getting nothing but have headlight horn blow an tap starter an only thing it doing is whering
Sep 23, 2009 at 10:20 AM
  • 75,988 POSTS
When you turn key to run -do you see all the lights that normally comes On? Is it cranking over and will not start? Answer this Q's and we'll get it going.
Sep 23, 2009 at 11:48 AM
RODWIGGINS
  • 10 POSTS
yes see all light but no will not crank nor turn motor over
Sep 24, 2009 at 8:20 AM
  • 75,988 POSTS
Have your battery load tested and if okay cleaned posts and cables and make sure its properly tightened-if it continues short out the starter solenoid if it cranks the engine -check and test the starter relay, park and neutral switch for 2.5L and transmission range switch for 4.0L engine to include the ignition switch
Don't crank the engine over remove starter and have tested.
Sep 24, 2009 at 9:32 AM
RODWIGGINS
  • 10 POSTS
will let u no if this solve the problem an wanted say thank but i think my starter is shot
Sep 24, 2009 at 9:57 AM
RODWIGGINS
  • 10 POSTS
if starter is there any way i can get it started or i will have to wait until i replace starter
Sep 24, 2009 at 10:02 AM
RODWIGGINS
  • 10 POSTS
mine v-8 5.2 liter autom...jeep grand cheerk...se
Sep 24, 2009 at 10:06 AM
  • 75,988 POSTS
No problem even if its V8 auto same circuitry.
Okay at the starter short out the battery terminal to the small terminal that has light green and black wire with a screwdriver-did the engine crank over? If not the starter is no good
Sep 24, 2009 at 10:57 AM
