1998 Jeep Cherokee
LADYQUEENCOBRA
  • 1998 JEEP CHEROKEE
Noises problem
1998 Jeep Cherokee Four Wheel Drive Manual 198000 miles
I have a 1998 Jeep Grand Cherokee. I went to start the ignition and the horn just keep going off until I turned the key back. Is there any whay you can help me?
Wednesday, August 25th, 2010 AT 2:08 PM
WRENCHTECH
  • 20,761 POSTS
You probably have a bad horn switch but most of them are part of the air bag now.
Wednesday, August 25th, 2010 AT 2:18 PM
LADYQUEENCOBRA
  • 6 POSTS
BUT THERE IS A KEY RIGHT BELOW THE STEERING WHEEL AND THE LIGHT KEEPS BLINKING. WHEN WE PURCHASED THE VECHILE, WE WERE TOLD TO NEVER TOUCH IT OR IT WOULD TAKE A WHILE BEFORE IT BE ABLE TO CRANK. BUT IT JUST SO HAPPEN THAT THE OTHER DAY WHEN I WENT TO CRANK THE JEEP UP, THE HORN JUST WENT OFF. BUT I NEVER TOUCHED THE KEY.
Wednesday, August 25th, 2010 AT 9:27 PM
WRENCHTECH
  • 20,761 POSTS
The key should be just a starter lockout and nothing to do with the horn.
Thursday, August 26th, 2010 AT 4:18 AM
LADYQUEENCOBRA
  • 6 POSTS
Well its either the horn or the alarm, but its not cranking at all, what can I do to get it started?
Thursday, August 26th, 2010 AT 7:50 AM
WRENCHTECH
  • 20,761 POSTS
You never said it wouldn't start, just that the horn was going off. It sounds like the car has an aftermarket alarm system beyond just that key.
Try locking all the doors and unlock it from the tailgate and then the doors.
Thursday, August 26th, 2010 AT 8:07 AM
LADYQUEENCOBRA
  • 6 POSTS
I have already tried that and I tried taking the key out and putting it back in. Anything else I can do?
Thursday, August 26th, 2010 AT 8:57 AM
WRENCHTECH
  • 20,761 POSTS
I don't have anything else. The system seems to have a malfunction.
Thursday, August 26th, 2010 AT 9:06 AM
LADYQUEENCOBRA
  • 6 POSTS
Ok thanks a lot, but I know that the alarm system was put in after the fact and was not installed when it was built. Its all just so confusing to me, but thanks again.
Thursday, August 26th, 2010 AT 9:28 AM
WRENCHTECH
  • 20,761 POSTS
Here's one more thing that sometimes works.
Disconnect the battery. Turn the key on to the "run" position and then connect the battery back up with the key on and see if that works.
Thursday, August 26th, 2010 AT 11:13 AM
LADYQUEENCOBRA
  • 6 POSTS
Thanks a lot, I will try that.
Thursday, August 26th, 2010 AT 4:15 PM
