Brake/transmission keeps turning brown/dark green color
85,000 MILES • 1.4L • 2WD • MANUAL
LOUBCK
My gearbox has been difficult to change gear recently so I checked the transmission fluid and noticed it was a brown/dark green in color. I emptied the fluid and refilled it with brand new brake fluid.about a month later the gearbox was still difficult to change gear so I check the brake fluid again, and in just over a month the fluid has changed color again and not a single drop of the fluid has gone down, it is still full to the brim but now has an awful color?
Jun 16, 2020 at 1:24 AM
STEVE W.
  • 15,411 POSTS
I assume you mean the clutch reservoir fluid? From the description you likely will want to flush out the fluid system. It sounds like it may have been contaminated with oil or similar and that is causing problems. It may be too late now if it is also causing shifting issues as the slave cylinder may have seals that are starting to fail and it is bypassing fluid internally.
I would try doing a flush though, Basically you will need to get to the bleeder for the clutch, then draw out the dirty fluid from the reservoir with something like a turkey baster, fill it full of clean fluid, then open the bleeder and lightly pump the clutch, keep filling the reservoir as you do this, and keep going until the fluid out of the bleeder is the same as the clean fluid you are putting in.
If the fluid again changes color and you have shifting issues after the flush then it is likely either a bad master or slave cylinder that has internal parts that are failing.
Jun 16, 2020 at 2:56 AM
LOUBCK
Thank you for the reply Steve I really appreciate it. I will try what you advised first thing tomorrow morning! Cheers!
Jun 16, 2020 at 3:41 AM
STEVE W.
  • 15,411 POSTS
You're welcome. Let us know the results. I would also rub some of the fluid between your fingers, you are feeling for grit in the fluid. That can be a sign of corrosion and rust in the fitting, lines and cylinders. If it is black or looks streaky that can be the rubber components breaking down.
Jun 16, 2020 at 4:40 AM
