Brake pedal and brakes lights
124,324 MILES • V6 • 2WD • AUTOMATIC
L.W.JONES
  • 10 POSTS
The brake lights stay on while the truck is running and the pedal sags, but if I pull up on pedal the lights go off. Also from the pedal area I can here a vacuum sound, but when I pull the pedal up, it lets up ?
Mar 12, 2016 at 3:11 PM
  • 31,937 POSTS
It sounds like a leaking brake booster check this out, the vacuum noise can only be coming from the booster.
Mar 12, 2016 at 4:03 PM
L.W.JONES
  • 10 POSTS
Thanks that is what I thought, the booster is making the vacuum noise. Bad booster? Or fixable??
Mar 12, 2016 at 4:10 PM
  • 31,937 POSTS
Not worth the time or money these days doing self repairs on these units, go get a new or change over booster this will be quicker and in the long term cheaper fix.
Mar 12, 2016 at 4:18 PM
L.W.JONES
  • 10 POSTS
Thanks for your time and help.
Mar 12, 2016 at 4:21 PM
L.W.JONES
  • 10 POSTS
Will my master cylinder need to be replaced, or can I test it and use the old one?
Mar 12, 2016 at 4:45 PM
  • 31,937 POSTS
When you remove the master just make sure that the rear seal is not leaking fluid, if it is dry it will be fine to reuse, if leaking replace the master as well.
Mar 12, 2016 at 7:01 PM
L.W.JONES
  • 10 POSTS
Thanks you.
Mar 12, 2016 at 7:18 PM
  • 31,937 POSTS
Thank you for using 2carpros, feel free to repost if you have further problems.
Mar 12, 2016 at 9:46 PM
