Brake pedal goes to floor
194,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ITISME201411
  • 33 POSTS
I blew a brake line a couple weeks ago.So I decided to replace all of them as well as both front calipers,hoses,an back cylinders.they looked rusty an save myself the hassle.It all went good.I bleed the brakes 3 times an the pedal is still very spongy.I checked for leaks an couldnt find any.Think the master cylinder went?
Sep 24, 2017 at 12:25 AM
CARADIODOC
  • 34,413 POSTS
Most likely. It is important to never push the brake pedal to the floor. Crud and corrosion build up in the lower halves of the bores where the pistons do not normally travel. Running the pedal over half way, whether surprised by a sudden leak, or when pedal-bleeding with a helper, runs the rubber lip seals over that crud and can rip them. That results in a slowly-sinking brake pedal that often does not show up until two or three days later.
I only use gravity-bleeding with no helper. It takes a little longer, but I rarely run into a damaged master cylinder. When you do have to pump the pedal, such as when running the pistons out of the calipers, just be careful to not push the brake pedal over half way to the floor.
Sep 25, 2017 at 1:25 PM
