1992 GMC Truck stopped
1992 GMC TRUCK
210,000 MILES • 6 CYL • FWD • AUTOMATIC
PJMERRITT
My 92 GMC TRuck just stopped, I think, for good. Traveling down the road, engine stopped and brakes locked up. I had to add water before I left. We tried jumping it off and nothing happened. Horn and lights still work.
Jan 12, 2010 at 6:04 AM
MICKEY-D
  • 304 POSTS
I believe your engine has seized by the way you explained what happened. It's time to pull off the wipers, and slide a new truck under them!!
Seriously, if the truck itself is worth spending money on,(good body, drivetrain, brakes, front end)you might want to consider buying a crate motor. Check with your local parts houses, and you'll probably find some good deals.
mickey-d
Feb 23, 2010 at 4:25 AM
