Brake pads
213,674 MILES
UNCLE WILLY
What other vehicles share the same front brake pads as a 1998 Buick century?
Feb 26, 2016 at 10:10 AM
WRENCHTECH
  • 20,760 POSTS
Why would you want to know that? Are you considering putting used brake pads on?
Feb 18, 2021 at 9:47 AM
UNCLE WILLY
No. I Have several new brake pads from previous cars, and ones I picked up at estate auctions, but all purchases for different cars. I wanted to know if any will fit the car.
WRENCHTECH
  • 20,760 POSTS
There are hundreds of different part numbers for brake pads so the chances are minuscule at best. If they are a major brand you should be able to look up the application with a supplier that carries them.
UNCLE WILLY
I just thought maybe there was a list somewhere showing what cars shared the same brake pads.
WRENCHTECH
  • 20,760 POSTS
No, there is not sorry. In fact there could be two or three different possible applications for a single model because there are various optional brake packages available. There could even be three or four construction types for the the same application, such as semi-metallic, organic, ceramic or hybrid. All different performance. Unless you have a brand name and part number, there is really no way.
