Brake lights will not turn off
BIGRYAN
  • 14 POSTS
If the float is inside the master cylinder, how can I see it? The switch for the e-brake has been inspected and appears to be working fine.
Wednesday, October 23rd, 2019 AT 2:05 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Unplug the connector at the master cylinder to see if the light comes on. If it does not, plug it back in and retest.
One way of testing the switch is to use an ohmmeter to test for continuity. When fluid level is good, there should be no continuity between the 2 terminals of the switch.
BIGRYAN
  • 14 POSTS
It appears the ABS module is the cause, as there seems to be no communication with it. The ABS/traction control lights don't self-test on startup, and it seems the t/c is not working. The switch for the parking brake was faulty, and has been repaired. I replaced the switch at the master cylinder with no luck, but found the light stays off when it's unplugged. Good enough!
Thanks!
2CP-ARCHIVES
  • 4,540 POSTS
  • 1999 FORD TAURUS
  • 160,000 MILES
Why does my break warning light stays on when I don't have the parking breaks on. I don't know where to find the break fluid so I can check it.
KHLOW2008
  • 41,814 POSTS
Yes, a fault with the ABS system can cause the light to stay on. You would need to get a scan done to check for trouble codes and proceed from there.
HOMER1967
  • 875 POSTS
Low brake fluid is the next obvious cause. You check the fluid level in the master cylinder which is on the drivers side of the vehicle, mounted on the firewall, almost directly under the drivers side wiper blade.
JTHTCJV
  • 1999 FORD TAURUS
  • V8
  • 120,000 MILES
What would cause the brake light on dash to stay on
BLACKOP555
  • 10,371 POSTS
Does the system operate normally to you?
I would first check the brake fluid level to make sure thats not the problem.
The fluid level normal?
Get back to me.
JTHTCJV
Yes the brakes seem normal, the light comes on periodically
BLACKOP555
  • 10,371 POSTS
I would be checking the level of the fluid and the brake fluid level sensor if thats the case.
MELEEMASTA
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 100,000 MILES
My Driver side brake light is not coming on when I tap the brakes. My rear window brake light and passenger side brake light come on though however. And my rear lights that are on all all the time are working fine too. I checked the fuse box and that looks fine. What do you think could be the problem?
JGAROFALO
  • 489 POSTS
I would start by checking the bulb. Make sure it is fully seated in the socket, and that it is not burned out. If the bulb is OK, then check for loose connectors, broken ground, or wiring harness chafing.
JCM8JP
  • 1998 FORD TAURUS
  • 6 CYL
  • FWD
  • 141,000 MILES
The e brake light in my car stays on even when I take it off im not sure if I have a major problem or if I need some brake fluid
DAVE H
  • 13,384 POSTS
Check fluid level. If that is ok check the.
Parking Brake Switch. Under left side of dash, mounted above brake pedal.
CLINNELL
  • 1998 FORD TAURUS
Other Category problem
1998 Ford Taurus V6 Front Wheel Drive Automatic 67000 miles
My 98 Taurus brake lights lights are stuck on even after the car is shut off and nobody is touching them. Any ideas as to what that's about?
FLEXY5
  • 512 POSTS
Prblem is the brake light switch located on the brake pedal. It is a common problem that Ford addressed with a recall. Contact your local dealer to find out if it applies to your vehicle.
LUPE ROMO
  • 1998 FORD TAURUS
Electrical problem
1998 Ford Taurus 6 cyl All Wheel Drive Automatic
Sometime door lights stay on, and brake lights stay on and doors wont lock by them self.
Gas guage not reading right, I put 10.00 in gas.
As I am driveing down the street gas light comes on low fuel.
What should I do to correct. These problems?
SOMEONE PLEASE HELP ME.
Wednesday, October 23rd, 2019 AT 2:06 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Cluster codes is needed
most common
door switch (driver door switch would be the 1st to check if no scanner available to check )
fuel gauge suspect in-tank sender
