Brake warning light turned on?
194,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRANDONTRUENO86
  • 35 POSTS
This brake lamp light on my dash lit up today.. any ideas? The brake lights are working.
Apr 28, 2020 at 2:52 AM
The brake lamp is actually an indicator of the brake fluid level in the reservoir. So that means it is low for a reason due to this being a sealed system. This means it either has a leak or the brake pads are getting worn and it takes more brake fluid to extend the piston in the calipers to apply the brakes.
Here is a guide that covers this in a little more detail but I would start with removing the wheels and inspect the pads for needing to be replaced.
Review this and let me know what questions you have. Thanks
https://www.2carpros.com/articles/brake-system-warning-light-on
Apr 28, 2020 at 6:33 AM
BRANDONTRUENO86
  • 35 POSTS
This is extremely helpful. I know the pads are getting worn,they've been making noise for a week now. I'll check everything and do a brake job this week. Thank you
Apr 28, 2020 at 7:49 AM
Thank you. Please let us know how you make out or if you need more help. Thanks for coming back to 2CarPros.
Apr 29, 2020 at 10:44 AM
