Bogging sound at about 10 to 20 MPH?
2009 FORD MUSTANG
180,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MCVAY78
The car drives fine until I'm about to pull in or just going about 10 to 20 MPH. It sounds like the exhaust bogs down and the only way I can get it to stop is to come to a complete stop. And even then, it will make a knocking noise before it stops. It won't do this unless I'm on the road for over 10 minutes though.
Jul 3, 2024 at 6:59 AM
  • 110,194 POSTS
When I hear the word bogging, it indicates a lack of power from the engine. Have you noticed power loss?
If possible, could you record the sound and upload it for me to hear?
Let me know. Also, Happy 4th!!!
Jul 3, 2024 at 7:53 PM
MCVAY78
There is no power loss until this happens and it only does when I'm not pushing on the gas and between 10 and 20 MPH.
Jul 4, 2024 at 7:33 AM
  • 110,194 POSTS
I watched the video. I really don't like the engine sounds I'm hearing. It sounds like a lot of metallic sounds when it happened. Am I hearing it correctly? Pay attention if the sound is present regardless of speed and at the same RPM. In other words, if the engine RPMs are 1500 when this happens, see if the same thing will happen at 40 at the same RPMs.
Jul 4, 2024 at 7:45 PM
MCVAY78
It only does this when I'm going about 10 to 20 MPH. I never have any problem going any faster. The car shifts perfectly and still has all the power it should. Until then. And the only way I've found to make it stop is to gas on it while that sound is going on or to come to a compete stop. But then it usually happens again. But it takes a bit. I have to drive it for about 20 minutes maybe before that happens.
Jul 4, 2024 at 9:20 PM
  • 110,194 POSTS
That is an odd one. What I would suggest is to have the can-bus scanned.
CAN stands for controller area network. Basically, all the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing it.
Here is a link that shows how it's done:
If the problem would happen at any speed/RPM, I would think there was a fuel pressure issue. However, since it is so limited, I would try this to see if there are any codes stored. Otherwise, it will become a guessing game, and that can get expensive.
Let me know your thoughts.
Jul 6, 2024 at 9:22 PM
