2006 BMW X5 BMW 06 X5 3.0 vibrations when driving over 65 m
2006 BMW X5
18,000 MILES • 6 CYL • 4WD • AUTOMATIC
GMALIK
My BMW 06 X5 3.0 with 18 k miles starts vibratiing when driving around 65-80 mph. It doesn't look like tires or steering. It starts at different speed depending whether driving uphill, flat or downhill. Vibrations stop when gas pedal is released and then start again when accelerating. Becomes really violent if I don't slow down.
Dec 4, 2008 at 6:08 AM
DOCHAGERTY
  • 9,606 POSTS
Is the vehicle still under the factory warranty?
Dec 4, 2008 at 7:59 AM
GMALIK
Yes, it's still under the warranty. I will bring it in, was just wandering it could be, if anybody experirnced that.
Dec 4, 2008 at 10:48 PM
DOCHAGERTY
  • 9,606 POSTS
Yes I have experienced this issue and there could be several factors involved here. This will require the inspection of the vehicle and I am not able to do that from cyberspace, however, the problems that can cause this can be a tread separation in one or more of the tires or a drive shaft or half shaft being out of balance or perhaps being road damaged, even a bent wheel or a wheel that has had the balancing weights knocked off just to start the list of what it might be. Hope this helps you when you have the vehicle inspected at your "friendly" local BMW dealership. ♥
Dec 5, 2008 at 4:54 AM
