2001 BMW X5 ABS Light On After Brakes
MECHANICRG
ABS light on after changing brakes. How do I reset the system to turn the ABS light off? Sensors are connected and no fault codes! Light has been on for two months since replacing brakes.
Oct 17, 2007 at 4:25 AM
  • 55,845 POSTS
It sounds like the new rotors do not have the ABS wheel reluctor on them. Did you match the rotors up?
Here is a guide to help you test the BAS wheel speed sensors to confirm the problem.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Cheers, Ken
Aug 3, 2017 at 9:21 AM
MAYORG
high mileage, oil serviced recently, replaced spark plugs..
Aug 3, 2017 at 9:21 AM (Merged)
DAN_K
  • 213 POSTS
You will need to scan the vehicle to determine the Diagnostic Trouble Code (DTC) for the ABS system.
Begin your diagnosis there.
Suggested Repair
Confirm the replacement rotors have matching ABS reluctor rings, test the ABS wheel speed sensors, and scan the ABS system for diagnostic trouble codes.
Conversation Summary
The owner of a 2001 BMW X5 said the ABS light stayed on for two months after a brake job, with sensors connected and no fault codes found. One expert suggested the new rotors may lack ABS reluctor rings and recommended testing the wheel speed sensors. Another expert advised scanning the ABS system for diagnostic trouble codes. An unrelated comment about oil service and spark plugs did not add diagnostic detail.
