The car is a 1995 840 Ci. The plastic moulding around the left mirror is broken. How do I remove the mirror glass?
Sep 25, 2007 at 11:10 AM
DOCHAGERTY
✓Experienced Mechanic
first, pull the mirror out at the bottom as far as it will go.
there will be a plastic locking ring, it is white.
with a pick tool, rotate this ring and the mirror releases.
the remaining disassembly is straight forward as you will see
