1998 BMW 740 Brake Light Out
BMWMB
One of the three brake lights will not work. The other two work fine. I have installed all new bulbs. I have moved bulb holder and bulb from a good light to the defective light. The problem is in just that one light. Does each light have an individual fuse for a 1998 BMW 740iL?
Even at 85,000 miles, the car is like new. The wiring looks to be in good condition? I am baffled.
The defective light is the left or drivers side brake light. Everything else on the car works.
Nov 2, 2007 at 2:49 PM
DOCHAGERTY
  • 9,606 POSTS
is it the left, right or center light that is inoperative
Nov 2, 2007 at 11:29 PM
DOCHAGERTY
  • 9,606 POSTS
it is possible that the tail light assembly is faulty. remove the affected taillight and inspect the contacts.
if they are not free of pitting and/or corrosion they will require replacement. 9/98 production is where the
cutoff is. if you purchase a replacement be sure to bring the vehicle id # with you. 9/98 is a production change and the parts from early and late production are not interchangeable.
Nov 3, 2007 at 1:28 PM
Suggested Repair
Remove the left taillight assembly and inspect the contacts. If they are pitted or corroded, replace the assembly. A September 1998 production change means early and late parts are not interchangeable, so bring the vehicle identification number when ordering.
Conversation Summary
The owner of a 1998 BMW 740iL reports that the left brake light does not work while the other two do. New bulbs and swapping a known-good bulb and holder did not fix it, and the wiring looks sound. The expert advises removing the taillight to inspect the contacts for pitting or corrosion and replacing the assembly if needed, noting that early and late 1998 parts are not interchangeable.
