1990 BMW 735
JACKX1962
  • 29 POSTS
So I am guessing the motor needs to be lifted.
Thursday, April 30th, 2009 AT 12:23 PM
JACKX1962
  • 29 POSTS
So I was reading and I can take off the lower cross member to take off the oil pan. Do you still have to hold the motor up? I am just trying all the facts before I get into it.
Thursday, April 30th, 2009 AT 3:13 PM
DOCHAGERTY
  • 9,601 POSTS
Yeah, you want to hold the motor/tranny, and the sub frame drops out the bottom enough to get to the pan. Also the P/S pump/ alternator have to come loose and the bracket removed and the A/C pump and the bracket need to move out of the way.
Friday, May 1st, 2009 AT 12:29 AM
JACKX1962
  • 29 POSTS
How did you make out getting the code?
Friday, May 1st, 2009 AT 8:23 AM
DOCHAGERTY
  • 9,601 POSTS
I think it is 1-4-4-3-5
Saturday, May 2nd, 2009 AT 9:33 AM
JACKX1962
  • 29 POSTS
Thankyou I will try it. Do you know where the tranny mounts are on this.
Saturday, May 2nd, 2009 AT 11:00 AM
JACKX1962
  • 29 POSTS
The code did not work. I put it in the radio beeped but nothing happened.
Saturday, May 2nd, 2009 AT 12:36 PM
JACKX1962
  • 29 POSTS
I got the radio to work the code was 41264 I have a question how do I know if I have an auto leveling system? The back sits low and I was going to replace the shocks and he asked me if it had this system. I dont know.
Wednesday, May 6th, 2009 AT 7:14 PM
JACKX1962
  • 29 POSTS
How do you get the door chimes and the alarm on for when you leave your headlights to work. And also what does it mean when I am doing 40 mile per hr and hit the brakes the front end shakes.
Friday, June 5th, 2009 AT 8:58 PM
DOCHAGERTY
  • 9,601 POSTS
Auto leveling is identified by visually inspecting the rear shocks, look for a hydraulic line coming from the shocks to a black accumulator, if there you have self leveling.
Saturday, June 6th, 2009 AT 8:50 AM
JACKX1962
  • 29 POSTS
Is it possable to change that system to a regular shock and is it hard to convert?
Saturday, June 6th, 2009 AT 9:39 AM
DOCHAGERTY
  • 9,601 POSTS
The question about the front end shake is you need to replace the thrust arm bushings, and the rear shocks can be swapped out for non self leveling, call (619)444-2290 for the replacements, talk to John or Sean. The hoses going from the accumulators to the shocks get plugged because you cannot remove the hydraulic part, you just abandon it in place. The reason is the power steering pump is a tandem pump, part of it runs the power steering, part of it runs the self leveling, and I just cap it off at the "bomb" (accumulator)
Tuesday, June 9th, 2009 AT 8:54 AM
JACKX1962
  • 29 POSTS
Thankyou
Tuesday, June 9th, 2009 AT 8:59 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Have you seen this one?
https://www.2carpros.com/first_things/1996_2005_bmw_vw_audi_water_pump_failure.htm
does this help?
Tuesday, June 9th, 2009 AT 5:19 PM
JACKX1962
  • 29 POSTS
Yes thankyou I change the waterpump 100% better
Tuesday, June 9th, 2009 AT 6:59 PM
JACKX1962
  • 29 POSTS
I have 2 questions on the computer readout on the dash it says Break cercuit Lt what does that mean and also I am going to install new control arms with the thrust bearing and balljoint installed. Is there speacial tools for this. I am going to replace both sides.
Thursday, June 11th, 2009 AT 7:01 PM
DOCHAGERTY
  • 9,601 POSTS
The brake issue will require replacement of the brake light switch. The tool for the front arms is commercially available. Baum tool or Hazet should be able to supply the need, or Snap-on for too much $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Thursday, June 11th, 2009 AT 11:46 PM
JACKX1962
  • 29 POSTS
Would it be the upper or lower arms?
Sunday, June 14th, 2009 AT 3:47 PM
DOCHAGERTY
  • 9,601 POSTS
The lower ones.
Sunday, June 14th, 2009 AT 9:12 PM
JACKX1962
  • 29 POSTS
Hello my drivers door when unlocking you have to lift the handle to get it to unlock is this comon in this car and also when I lock it the passenger door dont lock. Does this mean the actuators are no good.
Friday, June 19th, 2009 AT 6:47 AM
