my bmw doesn't start
GINASTER
Hello.
I have a BMW 530d, 2000, 265.000 km, automatic. If I go with it somewhere and I use it for 20 minutes in the traffic and then I stop it, and I let it for 15-20 - 1h period of time, it won't start. The mechanic changed: the fuel injector, the pomp of fuel, the water cooler system and it's still acting the same. I leave it everyday in other parts of the city coz it just doesn't want to start. If I leave it for 4-5 hours, then it starts, otherwise, no chance. Any idea what the problem might be ? If they test it with the machine, everything is in order...
problems which occurred from time to time:
- sometimes the alarm is not working
- one of the 5 injectors works at 40%
- sometimes the key is not working at all, it doesn't open the car, is dead
- sometimes the air conditioning is not working and it heats the car instead of cooling it
- sometimes it doesn't heat it at all but only cools it
Does anyone know what the problem might be ? My mechanic is confused too :-(
Thank you,
Gina
Nov 28, 2007 at 8:53 PM
DOCHAGERTY
  • 9,606 POSTS
Gina, send me the vehicle identification number and we will try to help. Please know that I am in the U.S.A. and we do not get the diesel cars on this side of the pond.
Dec 3, 2007 at 8:02 AM
GINASTER
Hello again. I didn't know anyone would answer. The VIN is: GX42968.
Tnx.
Dec 3, 2007 at 6:54 PM
DOCHAGERTY
  • 9,606 POSTS
The only thing I might add is from my diesel experience with big trucks as I have never worked on BMW diesels is there may be a fuel contamination issue or the fuel is not rated at what the manufacturer requests. Is the fuel return blocked? Do you get excessive smoke when it does start? There may also be an electrical gremlin in there somewhere. Are you dealing with a BMW diesel mechanic who is factory schooled? I really do wish I could be more help to you, sorry.
Dec 4, 2007 at 2:50 AM
COGNITO
  • 28 POSTS
I would confirm your engine oil viscosity and do a compression check. Also check for excessive crankcase pressure" blow by".
Mar 12, 2008 at 3:46 PM
ANDYROSE
i had the same problem with it not starting, was told the, injector pump etc, it was in fact the cam censor, £75 fitted it myself. when this censor does not work properly it gives the wrong reading and does not let fuel to the pump. hope this helps. please let me know
andy
Feb 6, 2009 at 7:19 AM
