2001 BMW 530
PAULRMUR
  • 2001 BMW 530
  • 6 CYL
  • MANUAL
  • 130,000 MILES
Replaced the head gasket due to overheating. Followed instruction for the DOHC shaft & timing chains installation. Did not have the special tool for the air pressure through the oil vanos. Vehical starts and seems fine until I accellerate thus hesitation begins. Would skipping the air pressure through the oil vanos cause this and if not what could be the problem causing the hesitation when I attempt to accellerate?
Wednesday, July 23rd, 2008 AT 8:13 PM
DOCHAGERTY
  • 9,601 POSTS
The M-54 motors require special tools to set the vanos in the correct place, you cannot guess at it. They also require tools to set the intermediate chain. You will need to borrow, or buy the aforementioned tools to complete this job.
Wednesday, July 23rd, 2008 AT 8:22 PM
