1997 BMW 528 DSC Light On
MARIAG
Hello, please help me. I have a 97 528 auto with 153K. I had a split coolant hose which i replaced this morning. The hose went from underneath the intake manifold around the back of wherever to the water pump. (it was the one on the right as you look on it from in front of the car) After much effort I managed to get it all done, then started the car to get heat to check for leaks. The yellow DSC warning light is on and wont go off. I have only had this car for a couple of months and although I have a workshop manual there isnt anything in there as to why this would have happened.
Can anyone help me please? Many hours of internet searching on a sunda when nowhere is open for me to call them have led me here.
Many Thanks, Maria
Nov 4, 2007 at 4:54 AM
DOCHAGERTY
  • 9,606 POSTS
The DSC light is probably on due to a component either being left unplugged or an outright failure (somewhat unlikely) Try this first, open the trunk and disconnect the battery for 15 minutes. This is what BMW calls a master battery reset, sort of like restarting a computer or control/alt/delete. Reconnect the battery and drive the car and report back with your results, I will check in later today. And Maria, do not panic, all is well, the DSC will not keep you from driving the car.BTW, DSC means dynamic stability control.
Nov 4, 2007 at 6:38 AM
MARIAG
Hello, thank you for your reply, I did what you said and no joy at all. We couldnt think of anything else that we could try so tomorrow I will be on the phone to BMW to get it booked in for diagnostics.
Thank you so much for your help, I really do appreciate it. Maria
Nov 5, 2007 at 5:26 AM
DOCHAGERTY
  • 9,606 POSTS
It was worth a try Maria. Keep in touch and please let me know what was wrong and what the repairs were.
Nov 5, 2007 at 5:55 AM
MARIAG
got it back from the garage just now, it was the throttle valve operating cable which had broken. i guess it was on its way out b4 i changed the hose cos the light would flicker on and off every now and again, so thankfully it wasnt anything i had disturbed when i changed the water hose.
Many Thanks again for your help, hope this reply can help someone else
Maria
Nov 9, 2007 at 2:50 AM
DOCHAGERTY
  • 9,606 POSTS
Wow a broken cable, who would of thought!
Nov 9, 2007 at 9:16 AM
BRADJABI
So what was the cost of fixing the broken wire?
Apr 17, 2009 at 10:34 AM
DOCHAGERTY
  • 9,606 POSTS
You might have to wait awhile for an answer.
Apr 17, 2009 at 11:59 AM
BRADJABI
So it there some kind of step-by-step procedure for diagnosing the problem or just random check of all sensors, wires, modules, etc?
Apr 20, 2009 at 11:47 AM
DOCHAGERTY
  • 9,606 POSTS
It is mostly just knowing the car.
May 30, 2009 at 11:29 AM
MARIAG
I am so sorry I havent been back on- i moved house and just didnt get round to it!
It cost me £100 GBP to get it fixed by BMW- I was really annoyed as the cable only cost £7 and I could have changed it over myself!!
Jun 19, 2009 at 3:32 AM
Suggested Repair
A battery disconnect reset did not clear the DSC light. The garage found a broken throttle valve operating cable; replacing that cable fixed the warning.
Conversation Summary
After replacing a coolant hose on a 1997 BMW 528, the DSC warning light stayed on. A master battery reset did not clear it. BMW diagnostics found a broken throttle valve operating cable, which the owner said had already been flickering the light. Repair cost about 100 GBP; the cable itself was about 7 GBP.
