2000 BMW 528 ABS Light and Brake Grind
DONNAMARIA
I have a 2000 BMW 528i with 132,000 miles. 6 cylinder. I think I am in big trouble with my car. My ABS light started coming on from time to time and would go out. This happened right after I had my brakes and pads replaced about 1 1/2 years ago. Two mechanics could not find anything wrong and said my brakes were still operable.Now about two weeks ago the ABS brake light will not go out.
When I first start up my car, I get all of the test lights, then all the lights go out as normal. I put my foot on the brake and put the car in gear and pull away okay. At this point I do not have any ABS lights coming on. When I attempt to make my first stop at a traffic light, etc.. and apply the brakes, my brakes make a grinding sound and then the brake pedal pushes up towards me, and then I hear this clicking sound in the rear wheels. To make matters worse, the car starts to jerk and pulse and slow down in speed while my foot is on the accelerator. I would assume this is what locking brakes feel like.
I just know I am in for about three paychecks worth of work.
Mar 20, 2007 at 5:48 AM
MERLIN2021
  • 17,250 POSTS
Your problem is that when you had the brakes done a year and a half ago...you should have gone back with the car till they fixed it.
It sounds like a frozen caliper of two... :?:
Apr 2, 2007 at 8:25 AM
Suggested Repair
Have the brake calipers inspected for a frozen caliper, possibly one or two, related to the brake job done about a year and a half ago. Return the car to the shop that did the brakes until the fault is corrected.
Conversation Summary
The owner of a 2000 BMW 528i reports an ABS light that became constant after earlier intermittent warnings following a brake and pad replacement. On the first stop, the brakes grind, the pedal pushes back, the rear wheels click, and the car jerks and pulses as if the brakes are locking. The expert says the shop should have fixed the issue after that brake work and suspects one or two frozen calipers.
