1997 BMW 528 Light out indicator
1997 BMW 528
118,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALFORDTO
The indicator that tells you that you have a light out is showing that I have a bad bulb in the right rear, but all thr lights and flasher are working. Brakes, tail, signal, flasher, backup and everything. I disconnected the baterry and it went a way for a while but can back on the same day.
Feb 29, 2008 at 12:49 AM
DOCHAGERTY
  • 9,606 POSTS
Inspect all the bulbs for discoloration and replace with OE BMW bulbs if any show signs of age. Also inspect the bulbholders and the tail light assemblies for corrosion and/or pitting at the contacts. DO NOT USE BRASS BASE LIGHT BULBS, Use the stainless base bulbs from BMW.
Mar 3, 2008 at 7:05 AM
