1994 BMW 525i How to troubleshoot the air conditioner.
1994 BMW 525I
144,000 MILES • 6 CYL • 2WD • AUTOMATIC
MEKANIXE
The ac compressor clutch doesn't seem to engage when the ac switch is turned on. The fuses related to the ac circuit are ok. I have no idea if there is a relay and maybe defective. I also need to know the location of the relay. Your help will be greatly appreciated.
Oct 22, 2010 at 3:27 AM
DOCHAGERTY
  • 9,606 POSTS
For air conditioning to function properly there needs to be refrigerant in the system. I would start with checking the refrigerant charge. This work requires specific tools and equipment. From a safety standpoint, I recommend having an expert assist you rather than attempt the repairs yourself as there are high pressures to deal with and the possibility of personal injury is present. However, A/C gauges are available from the major parts suppliers as is refrigerant. A bit of study online might be very educational and I suggest caution when dealing with the unknown. Hopefully the issue can be resolved easily, please let me know your plan and we can see if there is someway to have this be a successful repair.
Oct 22, 2010 at 10:50 AM
MEKANIXE
Sir/Sirs,
The ac was working fine which means there is enough refrigerant in the system. For no reason, it just stopped blowing cold air and the ac compressor isn't engaging, so is that something of an electrical problem? Hopefully, you can help me with this and thank you in advance for all the help you will be extending me.
Oct 22, 2010 at 7:11 PM
DOCHAGERTY
  • 9,606 POSTS
I will look to see what the possible solution for the E-34 body style could be and repost straightaway.
Oct 23, 2010 at 2:04 AM
