We replaced the head gasket and found obvious damage to the old gasket were it was blown, I also had the head checked it came back fine no cracks or damage. Put the car back together following the torque specs. Started the car but it is boiling over and not all the hoses are getting hot, for instance upper radiator hose is getting hot lower radiator hose is not hot the radiator is cold also. There is a hose on the back of the head that goes to the heater core and that hose as well is cold. The cooling system is building pressure. It has a new clutch fan and thermostat I have even removed the thermostat to ensure that was not the problem. Any suggestions would be great.
THANKS
Brian
THANKS
Brian
Dec 18, 2008 at 3:55 AM
