1989 BMW 525i overheating no heat and antifreeze leak
14,900 MILES • 6 CYL • 2WD • AUTOMATIC
ARUFFIN2
I have a 1989 525i which recently lost heat and then begin to overheated. When I pulled over and opened the hood antifreeze looked like it was squiting out of a hole in the Idle Control Valve. Is this possible, or is there something else there that I may have missed?
Jan 7, 2010 at 7:29 AM
  • 75,988 POSTS
You might wanna start by replacing the thermostat-coolant coming out of the idle air control valve is an indication of a major trouble-could be the headgasket cracked head or block and intake manifold leak
Jan 7, 2010 at 8:15 AM
DOCHAGERTY
  • 9,606 POSTS
The M-20 motor uses a throttle body heater, cap off the hoses or replace the gasket of the heater cap at the throttle body.
Jan 8, 2010 at 12:46 AM
