1990 BMW 525 Overheats When Parked
YANNAL
I have a 1990 BMW 525I straight 6 with 150k Miles on it runs like a dream never over heat while am driving it but if i parked it and kept it running for over a 5 minutes it will over heat once i start driving it again it will cool down, so what should i check in this case i appreciate any help.
Aug 19, 2007 at 3:51 PM
DOCHAGERTY
  • 9,606 POSTS
With the age and mileage of the vehicle, I would say that the fan clutch is failing at it's duty. The part number you need to ask for is 11-52-7-502-804. Have a cool day.
Aug 20, 2007 at 9:31 AM
Suggested Repair
Inspect and replace the failing fan clutch (BMW part 11-52-7-502-804), which is the likely cause of overheating at idle.
Conversation Summary
A 1990 BMW 525i with 150,000 miles runs normally and does not overheat while driving, but overheats if left idling for more than about five minutes and cools again once underway. The expert attributes this to a failing fan clutch given the vehicle's age and mileage and recommends replacing it with part 11-52-7-502-804.
