front end shakes when slowing down
PLATO526
I have a 1991 BMW 525i with 200,000 KM on it. The front end starts shaking when I try to slow down from speeds above 90KPH. What could be the problem?
Jul 3, 2006 at 6:09 PM
YY
  • 10 POSTS
You may have warped disc brake rotors. This will cause your car to shake when braking. Also, check your front wheel alignment as this will also cause wheel shake. It is also a good idea to check your tire air pressure and tires.
Jul 15, 2006 at 3:41 PM
2CARPRO JACK
  • 11,533 POSTS
If it only does it on the brakes then its probably warped rotors, have the tires inspected to see if ones seperating
Jul 24, 2006 at 5:50 AM
