1991 BMW 525i Front End Shake
PLATO526
I have a 1991 BMW 525i with 200,000 KM on it. The front end starts shaking when I try to slow down from speeds above 90KPH. What could be the problem?
Jul 3, 2006 at 6:09 PM
YY
  • 10 POSTS
You may have warped disc brake rotors. This will cause your car to shake when braking. Also, check your front wheel alignment as this will also cause wheel shake. It is also a good idea to check your tire air pressure and tires.
Jul 15, 2006 at 3:41 PM
2CARPRO JACK
  • 11,533 POSTS
If it only does it on the brakes then its probably warped rotors, have the tires inspected to see if ones seperating
Jul 24, 2006 at 5:50 AM
Suggested Repair
If the shake occurs only while braking, inspect the front brake rotors for warping and replace or resurface as needed. Also have the tires checked for separation, verify tire pressure, and check front wheel alignment.
Conversation Summary
The owner of a 1991 BMW 525i with 200,000 km reported front-end shaking when slowing from speeds above 90 kph. Replies suggested warped brake rotors if the shake happens only during braking, plus inspection of the tires for separation, tire pressure, and front wheel alignment.
