1995 BMW 525 Dead Radio
GREENTEETH
I have a 1995 BMW 525i with 195,000 miles and it is a 6 cyl. . I left my key turned on and the battery went dead. Now my radio will not work. What has happened.
Sep 2, 2007 at 2:40 AM
DOCHAGERTY
  • 9,606 POSTS
there is a code that is needed. it is available from the dealer. you will need to get the serial # from the back of the radio and give it to the dealer, they will be able to get you your radio code. remember to write this code down someplace you can refer to it. some dealers will request a fee as they now have to file a PUMA case for radio codes.
Sep 2, 2007 at 10:17 AM
THEYCALLMEPHIL
[quote:549195d525="Dr. Hagerty"]there is a code that is needed. it is available from the dealer. you will need to get the serial # from the back of the radio and give it to the dealer, they will be able to get you your radio code. remember to write this code down someplace you can refer to it. some dealers will request a fee as they now have to file a PUMA case for radio codes.[/quote:549195d525]
i have the same exact problem. i went to the dealer, got the code and entered it.. the radio still wont work and the dealer told me to drive around for one hour. rofl
i drove for five! gas $ much!?
i need help!
Oct 27, 2007 at 3:03 AM
DOCHAGERTY
  • 9,606 POSTS
if you entered the correct code in the correct sequence
and there is still no joy, replace the radio.
the after market is your world.
Oct 28, 2007 at 4:43 PM
Suggested Repair
Get the radio security code from a BMW dealer using the serial number on the back of the radio, enter it in the correct sequence, and write the code down. If the correct code does not restore the radio, replace it; an aftermarket radio is an option.
Conversation Summary
A 1995 BMW 525i radio stopped working after the key was left on and the battery went dead. The expert said the radio needs a security code from the dealer, obtained with the serial number from the back of the unit, and advised recording the code because some dealers charge a fee. Another owner reported entering a dealer-supplied code without success despite driving for several hours. The expert then said that if the correct code was entered in the correct sequence, the radio should be replaced, including with an aftermarket unit.
