1991 BMW 525i
PJULIAN
My BMW is overheating. Radiator has been flushed and I replaced the thermostat. There is no problem with the return. Does the aux fan kick on when the temp goes up, plus she overheats in about 5 minutes.
Apr 8, 2006 at 6:37 AM
SUNWINMAN
Hello buddy,
please make sure that coolant is not leaking and once u filled the coolant hope u have done the coolant bleeding also to remove the air.
If the engine heats up when the car is idling,then there is a problem with the fan clutch.
with regards,
sunwinman
Jul 8, 2006 at 7:35 PM
2CARPRO JACK
  • 11,533 POSTS
the aux fan should come on when the engine gets hot.Have it chemical tested for a blown head-gasket so you dont chase your tail replacing parts
Jul 24, 2006 at 6:00 AM
