2004 BMW 330 leak
FLOYD RONERTSON
Engine Cooling problem
2004 BMW 330 6 cyl Two Wheel Drive Manual
leaking small amounts of antifreeze after running
Feb 1, 2010 at 5:28 PM
DAYCLONE
  • 16 POSTS
This is a very general stated problem...
Most common issues with the BMW's is that the leak is coming from the hose, the expansion tank, or if your vehicle is a 02+ there's a coolant sensor that runs off of the radiator on the passenger side by the washer fluid that sometimes the gasket goes and causes leaks.
Hope that helps!
Feb 20, 2010 at 6:06 PM
