I recently overheated in me BMW 330ci, no pipe leak, I changed thermostat and waterpump. When I run engine its seems fine, but shouldn't the cooling fan kick in if you leave engine running for about 15minutes and turn on AC and heaters.
I need to know whether it is the fan or fan switch, my friend directly linked a battery charger to the Fan with a some wire r but the fan did not kick in?
Mar 5, 2009 at 8:06 AM
