1985 BMW 325 Speedometer Not Working
C_DECLERCQ
the speedometer began to work erradically, sometimes indicating speed. After a week of sporadic behavior, the speedometer no longer measures any speed. Could it be a fuse? What can I do to fix the problem or trouble shoot?
Nov 18, 2007 at 6:53 AM
DOCHAGERTY
  • 9,606 POSTS
Please repost with the production date and the last seven digits of the vehicle identification number
Nov 18, 2007 at 7:54 AM
C_DECLERCQ
It's a 1985 325e, 6 cylinder engine, with approximately 130k miles. I don't have the vin number available at this time.
Nov 18, 2007 at 8:26 AM
DOCHAGERTY
  • 9,606 POSTS
Thank you for the undated information. The most likely cause of the problem is the driver for the speedometer. the easiest and quickest fix is to replace the complete speedometer assembly. This is a part you can find in a salvage yard. Send me a PM and I can recommend one.
Nov 18, 2007 at 9:22 AM
Suggested Repair
The most likely cause is the speedometer driver. Replace the complete speedometer assembly, which can often be sourced from a salvage yard.
Conversation Summary
The owner of a 1985 BMW 325e said the speedometer became erratic and then stopped working, and asked whether a fuse could be responsible. After requesting production and VIN details, the expert identified the speedometer driver as the most likely cause and recommended replacing the complete speedometer assembly, possibly with a salvage-yard unit.
