1995 BMW 325i Console Vibration
CEASAR757
I just got a manual 1995 325i convertible BMW v6 with 145382 miles... while accelorating the middel console is making a loud vibration/clicking noise. Usually happens when accelerating in 1st and 2nd gear, switching gears, and whenever I am going up hill or press the gas too fast... I don’t know if it is a problem with the clutch or something to do with the emergency brake... PLEASE HELP ME!!! I appreciate it
Chris
Oct 10, 2007 at 12:18 AM
DOCHAGERTY
  • 9,606 POSTS
you have described a failed center support bearing
for the driveshaft.
this may require replacement of the driveshaft
Oct 10, 2007 at 4:27 AM
Suggested Repair
Inspect and replace the failed driveshaft center support bearing. Driveshaft replacement may be required.
Conversation Summary
The owner of a 1995 BMW 325i convertible reports loud vibration and clicking from the center console when accelerating in lower gears, shifting, climbing hills, or pressing the gas quickly. The expert identifies a failed driveshaft center support bearing and says the driveshaft may need replacement.
