1994 BMW 325 hot wires after turn off
1994 BMW 325
186,000 MILES • 6 CYL • 2WD • MANUAL
KONCAL2
I have a 1994 325I convertible, when I turn off the key the engine keeps going. When I pop the clutch to kill the engine there are still things using power. Checked it out & two main wires are still hot. The lights for the mileage part of the dash work. The accessories, like the radio do not.
May 15, 2009 at 11:01 AM
DOCHAGERTY
  • 9,606 POSTS
Was the radio/alarm involved, was it an aftermarket system?
May 23, 2009 at 3:41 PM
KONCAL2
Yes the radio system was put in a couple of years ago.
May 27, 2009 at 4:03 AM
DOCHAGERTY
  • 9,606 POSTS
It sounds like the ignition lock inside the steering column is broken and is not shutting the electrical portion of the lock go all the way to shut the car down. The steering column will need to be removed and it will require some special tools. Do you have the tools and ability?
May 27, 2009 at 6:38 AM
KONCAL2
My son has done some work on the car, so he may be able to handle this.
May 28, 2009 at 4:23 AM
DOCHAGERTY
  • 9,606 POSTS
Good deal, let me know if you need help.
May 28, 2009 at 7:22 AM
