The sunroof sunshade is broken. A piece broke off the track and when the sunroof retracted it jammed. It burnt the sun roof motor out and blew the fuse. I replaced the motor and replaced the 30 AMP fuse with a 20 amp fuse, just in case.
How do reapir the sunshade. My haynes book says to take it to the BMW service. The BMW discs that I have bought off ebay is not very good. Any suggestions.
SPONSORED LINKS
Monday, June 1st, 2009 AT 10:44 PM
DOCHAGERTY
MECHANIC
Push the shade back and remove the sunroof lid, there are three Torx screws on each side. Then you can access the shade. Get the correct repair kit from BMW ( there is an early and late style)
