1995 BMW 325 not starting
EMERAZ15
  • 1995 BMW 325
  • 6 CYL
  • 115,000 MILES
I dont know what to do anymore I need help. I was driving my 1995 bmw 325i and it was working fine, I came home in the afternoon and it was running fine. The next morning I tried to start it and it would try to start but failed. I left it alone for a month because I dint have the time and money to fix it because I have another car so I dint pay much attention to it. Now that im on vacation im trying to get it fixed. It wouldnt start so I gave it a jump and it started which it didnt do before. But when I turned it back off and tried turning it on it wouldnt start. I changed the battery and it still does the same problem. I thought it couldve been my starter but it seems to be in working condition according to my mechanic and the fuel pump seems to be working to. What could be the problem, can you help me in figuring out whats wrong with it. Oh and I had the o2 sensore changed 2 weeks before the problem but where I took the car they told me I needed to perform a fuel injection cleaning but I didnt trust their opinion because they looked a little shady and I regretted taking my car there.
Saturday, November 6th, 2010 AT 6:48 PM
If its not being caused by the security system and its cranking over and will not start do below to determine if its fuel or spark problem and get back with some testing results we start here
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sunday, November 7th, 2010 AT 8:54 AM
DOCHAGERTY
  • 9,601 POSTS
Was the issue resolved?
Tuesday, January 11th, 2011 AT 12:47 AM
