1995 BMW 325 Cabin Air Filter
1995 BMW 325
107,000 MILES • 6 CYL • FWD • AUTOMATIC
BLUEFIRE13
Where is the cabin air filter located in my car?
Jun 8, 2008 at 4:37 AM
DOCHAGERTY
  • 9,606 POSTS
It is located behind and to the left of the glovebox. It is usually easier to remove the glovebox to access the filter. There is a plastic cover that has a Torx screw at the bottom and a lever at the top, remove the screw and rotate the handle to remove the cover and you will then be able to access the filter.
Jun 8, 2008 at 5:04 AM
