1995 BMW 325 BMW grinding and vibrations at 50+ on right tu
104,000 MILES • 6 CYL • 2WD • MANUAL
CARCLUELESS
I just purchased a 95 bmw. I just took it out on the highway. Everything seemed to be fine until I started turning the wheel to the right at higher speeds. It didnt happen every time but became more frequent. I can only describe the noise as a low grumbling rattlie. Where do I start?
Aug 27, 2010 at 1:50 AM
DOCHAGERTY
  • 9,606 POSTS
Thank you for your donation and for your description of the problem. The problem is most likely a wheel bearing noise, the left one is the possible culprit. Lift the left wheel off the ground and give it a spin, any rumble heard or felt will confirm the diagnosis. They are not difficult to install, they require a puller for the bearing race, they often get stuck. Here is a link to the part: http://www.realoem.com/bmw/showparts.do?model=CB43&mospid=47498&btnr=31_0424&hg=31&fg=10
Aug 27, 2010 at 5:45 AM
