1994 BMW 325 Fan
TMAYHALL
  • 1994 BMW 325
Engine Cooling problem
1994 BMW 325 6 cyl Two Wheel Drive 130000 miles
Can you give me some tips on replacing the fan on this car. Several of the blades have broken off.
Sunday, December 7th, 2008 AT 10:42 PM
DOCHAGERTY
  • 9,601 POSTS
Which fan are you asking about? The auxiliary fan or the heater blower fan?
Monday, December 8th, 2008 AT 12:43 PM
TMAYHALL
Fan connected to the water pump
Monday, December 8th, 2008 AT 2:44 PM
DOCHAGERTY
  • 9,601 POSTS
Thank you for re-posting! The fan clutch will require a 36mm thin wrench and is a left hand thread. Often a few sharp whacks with a hammer will achieve the desired results, if it is stubborn it may require a holding tool to intercept the water pump bolts. DO NOT OVER TIGHTEN IT WHEN REINSTALLING please, I might be the next guy to take it loose and I HATE IT when the damn thing was overtightened! It is a left hand thread so that when the engine is running, it tightens the nut.
Monday, December 8th, 2008 AT 5:47 PM
