1987 BMW 325 car starts to over heat
1987 BMW 325
25,000 MILES • 6 CYL • 2WD • MANUAL
MIKE JAG
car heating gauge goes close to hot when i turn on the AC. It does not do it when the AC is off. The radiator fan in front of the rad. is on and so is the one in back of it. What could be the problem. I had it flushed out with new antifreeze to see if that would help. It did a little, but still gets hot. thanks, Mike
Jun 14, 2009 at 10:51 PM
MIKE JAG
[quote:ab99ac98b5="mike jag"]Air Conditioning problem
1987 BMW 325 6 cyl Two Wheel Drive Manual 250,00 miles
car heating gauge goes close to hot when i turn on the AC. It does not do it when the AC is off. The radiator fan in front of the rad. is on and so is the one in back of it. What could be the problem. I had it flushed out with new antifreeze to see if that would help. It did a little, but still gets hot. thanks, Mike[/quote:ab99ac98b5]
Jun 14, 2009 at 10:52 PM
DR LOOT
  • CERTIFIED EXPERT
  • 2,311 POSTS
Assuming the car runs for extended periods without overheating as long the air conditioning is off, it is unlikely that you have a coolant circulation problem. That leaves poor heat to air transfer as the problem. The most likely cause of that would be a weak fan clutch. Use a popsicle stick to put drag on the mechanical fan from the back side (Yes, I mean letting the moving blades hit it). If you can easily stop it, then the fan clutch is kaputt and you need to replace it. If you can't stop it easily, then look for clogging in the radiator fins. I once spent a half an hour with a pressure washer blowing cottontree fuzz out of a woman's radiator. It fixed her problem. Other than that, it could be internal clogging from corrosion inside the radiator.
BTW, if you have to remove the fan clutch, you need to use an inch and a quarter open end wrench turning it in a reverse direction. Don't make the mistake of trying to unloosen the 10mm cap screws on the water pump pulley.
Good Luck,
Dr. Loot's Assistant
Aug 1, 2009 at 9:33 AM
