1994 BMW 325 overheating
MAP90066
  • 1994 BMW 325
  • 6 CYL
  • 175,000 MILES
My cars heated valve blew apart and my car overheated. I put a used one back in and filled the system with anti freeze it took about 3/4 of the gallon. I then started the car and letb run for a few minutes then opened the bleeder valve till fluid came out. Now the car is still overheating. Can you help?
Sunday, November 23rd, 2008 AT 8:28 PM
  • 31,937 POSTS
Hi there,
I would be checking the thermostat is opening fully and having the radiator removed and professionally cleaned & flow tested, often when an engine has had an overheating event, sediment that this in the block is stirred up and can be deposited in the radiator causing a circulation problem, have this check out.
Mark (mhpautos)
Monday, November 24th, 2008 AT 2:58 AM
