I have replaced the clutch master and slave clyinder while replacing the clutch. 1. While bleeding the clutch I have no clutch pedal. The pedal goes to the floor and stays there. I have used 12oz and have purchased 1 qt of brake fluid to complete the repair. Is this normal to use so much fluid and still not have a firm pedal? There is s squeeking noise from the clutch pedal. My guess is it is the spring. I used a torque wrench to install new parts. I didnt replace the spring or plastic covers on end of spring. They were installed according to alldata. Any thoughts?
Oct 9, 2009 at 6:29 PM
