1986 BMW 325 Clutch Pedal pressure
1986 BMW 325
MRWATSON74
Transmission problem
1986 BMW 325 6 cyl Two Wheel Drive Manual
I'm having an issue with my clutch pedal. When I engage the clutch pedal, it has no pressure. I recently installed a new master cylinder. I check for leaks and there were none. From time to time, it will work, but when the outside temperature is very cold, the pedal has begun to travel straight to the floor. Will I have to replace the slave cylinder or will just a simple bleeding of it be fine?
Nov 26, 2008 at 2:04 AM
DOCHAGERTY
  • 9,606 POSTS
When you are dealing with older hydraulic systems, replacement of the master should of, in my opinion, been done in addition with the replacement of the slave cylinder too. So yes replace the slave and bleed the system and it should solve your issues.
Nov 26, 2008 at 5:59 AM
