1990 BMW 325 Air conditioner gets hot while sitting in traf
190,000 MILES • 6 CYL • 2WD • MANUAL
ANTHONY1871
I live in Las Vegas, NV and it gets very hot here in the summer. Temps can easily reach 115 or more. The problem that I am having is that while I am driving down the freeway or surface streets, the air conditioner blows ICE cold but shortly after coming to a stop because of traffic or a stop light, it quickly heats up. I assumed that maybe i had an over-heating issue but the temp gage sits just a little past the normal spot (roughly in the middle). i have gone through the cooling system because of over-heating issues in the past like ( new radiator, fan clutch, hoses, coolant, and aux. fan works just fine) i have not taken it to a machanic as of yet because i dont want to replace the whole cooling system or spend a fortune looking for what is really a simple part to replace. i hope that you can answer this issues and thank you for your time.
Apr 29, 2008 at 9:34 AM
DOCHAGERTY
  • 9,606 POSTS
If the auxiliary fan is not working the A/C wont either. It's the fan in front of the radiator. The current limiting resistor does fail and its p/n is 64-12-1-388-069. You may need to seek professional help for this repair. If you feel confident enough to attempt the repair, go to Amazon.com and order a Robert Bentley repair manual for your model BMW.
Apr 29, 2008 at 1:10 PM
