HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
BMW
325
Exterior Light
Brake Light
Switch
Replace/Remove
SPONSORED LINKS
1990 BMW 325
THOMPSOND81
MEMBER
1990 BMW 325
1990 BMW 325
Where would I find the brake switch to either replace and make my brake lights work again? How would I be able to repair the problem?
Monday, July 5th, 2010 AT 7:16 PM
DOCHAGERTY
MECHANIC
The brake switch is above the under dash cover, #6 in this link:
http://www.realoem.com/bmw/showparts.do?model=1423&mospid=47322&btnr=35_0183&hg=35&fg=05
As to the work itself, it seems fairly straightforward, a few tools and an half hour should do it.
SPONSORED LINKS
Tuesday, July 6th, 2010 AT 1:05 AM
Please
login
or
register
to post a reply.
Related Brake Light Switch Replace/Remove Content
1995 Bmw 325 Brake Light Switch Replacement
I Need Position On Bracket That Holds Switch
Asked by
bimmerhelp
1 IMAGE
1995
BMW 325
1988 Bmw 325 Brake Light Switch Location &...
Where Is It, What Tools Do I Need, And How Do I Adjust It? Please Help.
Asked by
rkfrank2
1 ANSWER
1988
BMW 325
1993 Bmw 325 Bmw 1993 Brake Light Circuit Failure
I Have A 1993 Bmw 325i. Check Console Says Break Circuit Failure. The Breaks Feel Fine. What Does That Mean. I Called A Local Dealer, They...
Asked by
RALPHRENN
1 ANSWER
1993
BMW 325
2003 Bmw 325 Car Does Not Idle Properly
2003 Bmw 325 6 Cyl Two Wheel Drive Manual 185k Miles If I Leave The Car Off For Over 4 Hours It Runs And Turns On Fine But If I Stop And...
Asked by
jzablocki18
2003
BMW 325
2006 Bmw 325
Brakes Problem 2006 Bmw 325 6 Cyl Two Wheel Drive Automatic How Do I Reset Service Light In Tv Screen, And Also Reset Brake Light...
Asked by
stisho1
1 ANSWER
2006
BMW 325
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Turn Signals Blink Fast
Have a Dim Headlight? - Try Replacing This!
Online car repair manuals
